2x converter, or no?
phil2602
Using Sony lenses, is it better to crop from a long lens image or to use a converter to do the cropping for you? Which will give me the better image quality?
Hi Phil, do you have any particular Sony lenses in mind?
phil2602
I was thinking generally but I am keen to purchase the e mount 24-240mm lens for my A7 mk3. Would it be better just to get a 2x converter?
