A7iii. Wireless flashes
Maxim4646
Hallo!!!
I am interested in macro. Going to buy A7iii.
Can you, please, advice regarding the following:
1. Is it possible to connect wireless 2 Sony flashes to this camera?
2. Do I need to buy Wireless radio commander or the camera can run 2 wireless flashes by itself?
I did not find this information in Instructions to the camera...
Thanks in advance!
Hi Maxim, we're currently looking into this and will get back to you as soon as we have an update.
Almou_10
Specialist
Hi Maxim4646,
I guess checking the flash compatibility page in the following link can answer these questions: https://bit.ly/2PeUbxj.
You can find there all the compatible flashes, when you click on any of these flashes it will tell you what's required with this flash to work on the A7M3.
Hope this helps,
Almou_10
