A7R4 Camera
gordonelll
A7R4 Camera
I need a cable from the multi socket to PC Win 10, can't find a part no. anywhere.
Gordon
IamNic
Hello @gordonelll,
it is just a normal micro-USB to USB-A cable.
The port is just called "MULTI", since it supports accessories as well, which have a connector shaped like micro-USB but longer.
- Nic
Hi there,
It might be best to contact Sony support here.
Let us know how you get on. :slight_smile:
Best wishes,
M
IamNic
Hello @gordonelll,
- Nic
gordonelll
Thanks I thought so but am happy to be reassured.
Gordon
