A7R4 Histogram not visible when adjusting aperture
aroakley
Is there a way to move the location of the histogram?
It's really unusable when trying to adjust the aperture (or shutter speed) to get correct exposure. As soon as the aperture is adjusted, the histogram vanishes to be replaced with the aperture / shutter speed display and then it's necessary to wait before the histogram reappears. It makes real time adjustment impossible! Come on Sony, you GUI developers are half asleep!
EdwinaU
Moderator
Hi there,
Welcome to the community.
We will look into this and get back to you when we have more information.
Maybe some of our members will also have some information to share.
Best wishes,
Ed
The_Black_Rose
Specialist
Hi Aroakley,
I've just checked the manual of the camera and I couldn't find anything that would move the histogram's location: https://helpguide.sony.net/ilc/1930/v1/en/contents/TP0002711816.html?search=HISTOGRAM
However, I hope that Sony reviews this in the future.
Cheers,
The_Black_Rose
aroakley
Thanks for looking! I couldn't find a solution either. Hopefully it will be considered in future updates.
