Adobe CS4 Bridge and A580
chmclou77
I carn't see any of the raw file previews in CS4 Bridge. Bridge is fully updated but just not working. Anyone any ideas?
Message was edited by: chmclou77
Watashiwateshdes
When you say fully updated? I asume you mean you have the latest RAW update from the Adobe website which supports your Alpha?
If this is the case, you say you can not see any previews, but do you see a blank thumbnail or also, can you open up the image itself?
Watashiwateshdes
