Built-in Flash SONY NEX-3
profile.country.da_DK.title
OzZi1310
I have been searching for a Sony Nex 3. On a website they tells that Sony Nex 3 has an "built-in" flash?
Is that right?? Is there an built-in flash in the Sony Nex 3?.
Best Regards
Tags (2)
No the flash on a NEX-3 comes with the camera but is removable.
You can attach it when needed but take it off when you don't.
Have a look at this review: -
http://www.imaging-resource.com/PRODS/NEX3/NEX3FLASH.HTM
:wink:
:wink:
