Firmware update for A7iii?
walt_g
I was looking for a firmware update for my A7iii and noticed that there is an update for the A7Riii which allows that camera to bracket using uncompressed RAW. Any chance a similar upgrade is in the works for my camera? I shoot uncompressed RAW, but I have to switch to compressed RAW when I want to bracket because at present this is only possible with compressed RAW.
Sean_Mc
Moderator
Hi there,
To be informed about the latest firmware update for your camera, I would suggest downloading the 'Support by Sony' app which will keep you informed about the latest updates for your product.  More details on this here.
I will also forward your feedback to the team.
Best wishes,
Sean Mc
