Hi everybody; my subject is "Adapter "
Rhemsl21
I know that there are loads of adapter' out in the market as I write this. Question is which adapter could I use to an E-mount type  for my Nikon lens G AF-S DX lenses. I purchase an adapter for my  lens 70-300mm Nikkor G unfortunately it fit but it does not lock. I really would like to return it but it's a pain in my pocket because I paid only £12.00 and to return it, would cost me £6.00. Not so practical indeed. What I wanted to know, if there is 1 adapter only that could accommodate a Nikon lens. My camera is Sony a5000/ ILCE 5000L
Thank you,
Rhemsl21
Rhemsl21
Thalamus.
Champion
Hi Rhemsl21,
have a look at the extensive guide from Brian Smith hopefully it should help, if not let us know & we can try & help further..
Thalamus.
Champion
Hi Rhemsl21,
