How to transfer files from A6500 to a MacBook via wi-fi in 2020
Hi, guys! In Play Memory App was a function to set your computer as a device to send photos via Wi-Fi
Now we have a new app called Imaging Edge Desktop wich is useless window with links to real apps like Viewer, Remote, Edit.
Imaging Edge Desktop doesn't have any functions to pair MacBook with my Sony A6500.
So my camera A6500 search for my old MacBook and I can't connect new one.
I NEED STEB BY STEP INSTRUCTION HOW TO TRANSFER MY PHOTOS FROM A6500 TO MAC VIA WI-FI
EdwinaU
Moderator
Hi there,
Welcome to the community.
We'll check into this and let you know what we find. In the meantime, some of our members may be able to advise you.
Best wishes,
Ed
Joe_Dohn
Specialist
I've looked through the Manual and Help Guide and a bunch of other information on the Sony website, and there's this app called PlayMemories Home which you can install on your Mac (up to 10.13 High sierra) which does pretty much what you're looking for. Here's the link I found for it: http://support.d-imaging.sony.co.jp/www/disoft/int/playmemories-home/en/guide/mac/import/wi-fi.html
