I have an A300 Camera, can I use it some how as a webcam?
theracles
Having Googled, all the links returned totally ignore the fact that I specify the "A300" and just say "Any DSLR can be used as a webcam", going on to list eight or more Sony cameras with totally different names.
Is this something else mine can't do?😣
6 REPLIES 6
Pascale_F
Moderator
Hi theracles,
You might want to try contacting Sony Support about this.
Thanks,
Pascale
theracles
Thanks for that Pascale,
I won't get too excited as Sony seem to cease support for their products fairly early in their lives!
Regards and stay safe!
Geoff.
IamNic
Hello @theracles,
you just need this type of cable (found it on a German store), a video grabber of your choice and OBS with the plugin virtual cam.
- Nic
theracles
Hi IamNic, Thought for a minute that this would be what I need!
Just reading the Description, it says:- An audio-video cable for transmitting a signal in standard quality (SD) to a compatible television.Compatible
I want to connect the camera to my PC and for the PC (Windows 10 Pro) to "see" it as a webcam.
It doesn't seem to suit that use. 😞
IamNic
Hello @theracles,
it does, read my full comment please.
- Nic
theracles
I still don't understand.
I don't have the camera to hand at the moment, just the manual which shows a lead for TV connection with just a USB B male at one end and a single "Phono" or "RCA" type plug intended to connect to a TV.
The Grabbers you mention when I google for them all seem to comprise a standard "USB A" male plug with an array of three Phono sockets and a DIN socket!
