LA-EA2
jmlowerson
LA-EA2
Will any Sigma A Mount lenses work on the LA-EA2 E Mount Adapter?
Mick2011
Hi jmlowerson, welcome to the Sony Forums :slight_smile:
All modern ones should, yes. Unless you have some weird old Minolta-oriented incarnation needing special contacts on the body, or have an STF (Smooth Trans Focus) lens, anything made to fit Sony alphas should work with the EA2.
Mick
Mick2011
Mick
jmlowerson
Thanks Mick.
That's a great help!
Malcolm
Message was edited by: -Cass-
Edited post as contained personal information
