lens diformation
ssirianou
lens diformation
Hi, I have an a6000 16-50 lens, and when I use the 16 and shot with raw setting I get a deformation, how do I solve this? Thank you
Sean_Mc
Moderator
Hi there,
I'm looking into a solution for this and will update the thread when I have more information.  In the meantime perhaps another member of the community may be able to help with this.
Best wishes,
Sean Mc
IamNic
Hello @ssirianou,
do you mean, that you only have the issue when looking at your RAW files on your computer?
If the lens distortion doesn't appear, when shooting jpeg, it might be a preset of the software you use to view your photos.
- Nic
P.S.: This German post mentioned a similar problem: https://community.sony.de/t5/%C9%91-kameras-mit-wechselobjektiven/fisheye-effekt-bei-raw-bildern-alp...
