Lightroom wont show RAW preview?
iprior
Hi...suddenly, I get message instead of uploaded photos.." preview unavailable for this file. They all seem to be RAW files. Why has this just happened...and can I do something about it? thanks
sonyman1963
LR does not support your camera, so unless you choose to subscribe to the latest version of LR, which means a monthly subsciption, I suggest you do what I did, and switch to Capture One pro for Sony. Takes a bit of getting use to, but a couple of hours on youtube and you will have it cracked
iprior
ps..these files are only on my mem card or when I connect camera. They are available on my camera screen.
sonyman1963
