Live view on A6500
Live view on A6500
HI, I have just picked up an A6500 and I am wondering if it possible to focus manually with live view on the screen whilst using a 10 stop ND filter? Or do you have to focus your shot and then add the filter?
Hi there,
Hopefully a community member has had some experience with this and can help.
Best wishes,
M
Win_88
Specialist
Hi MissPippers
I don't see anything in the Help Guide that says you can't focus with the filter already on:
The limitations are mentioned here: https://helpguide.sony.net/ilc/1640/v1/en/contents/TP0001306108.html
Win_88
