manuele focus a77ii
denzelfleur
manuele focus a77ii
Hallo,
Wanneer ik manueel focus met mijn camera a77ii worden bepaalde velden in de zoeker wit verlicht.
Kan iemand me zeggen waar ik dit kan uitzetten?
Groetjes,
Denzelfleur
Are you referring to the white lines? Check Menu -> Gear -> 1 -> Zebra.
There is also the "Peaking Level" and "Peaking Colour" settings under Menu -> Gear -> 2.
Or are you perhaps referring to the white histogram on the bottom right? If so, you can cycle through the various configurations by pressing the "DISP" button on the back of the camera.
Otherwise, you will need to be more descriptive.
Regards,
Keith
Regards,
Keith
denzelfleur
Hi Keith,
Thanks for the info.
I was referring to the peaking and found it.
Thanks for your help
Kind regards,
Denzelfleur
