Monitor starting dimming randomly on a9ii
Hi
The monitor suddenly started dimming randomly, and the only solution is to hit play and then the shutter to come back to live view.
Sometimes it does it instantly and sometimes it doesn't do it at all. Any suggestions?
In the short video it is dimmed to begin with. I take some pictures, and when I view one of them and go back to live view, the monitor turns to normal brightness.
https://youtu.be/nC74D78Th_Q
dimmeddimmednormalnormal
Sean_Mc
Moderator
Hi there,
It sounds like the ISO sensitivity option is set to AUTO.  Can you let me know if you change to a different setting it fixes the problem?
Cheers,
Sean Mc
