NEX-5: Whats the difference: 16mm and 18-55mm lense?
profile.country.uk_UA.title
mykhalchevskyy
I would like to buy a SONY NEX 5... but which lense?
Can you please explain me whats the difference between 16mm and 18-55mm lenses and what are they better be used for?
The 16mm lens is small and light and is ideal for everyday use - particularly indoor/party situations,  However, it is a fixed wideangle lens - not a zoom - and does not have 'anti-shake' optical stabilisation included.
The 18 - 55mm lens is a standard zoom lens and includes Optical SteadyShot.  Although it is compact in size, it is larger than the 16mm.  his is a general usage all-round lens.
If you are only going to buy one lens, then the 18 - 55mm is the one to choose for an 'all-rounder'.
Have a look at all the lenses for the NEX-5 by clicking on the NEX-3 & NEX-5 Lenses link: -
http://www.sony.co.uk/product/dsi-body/nex-5d#pageType=Accessories
:wink:
sparklehedgehog
:slight_smile:
Message was edited by: sparklehedgehog
