NEX-7 with extra flashes
profile.country.fi_FI.title
HannuKaa
Canon Speedlite does not fit in NEX-7. What is needed to connect EL-Skyport to NEX-7 and shoot the flash/flashes with skyport system? Several options?
Watashiwateshdes
You have two options if you plan to go down a third party flash route.
FA-ST1AM which gives you a PC Sync connection
FA-HS1AM gives you a standard hot shoe port for mounting on triggers and then allow you in turn to use third party units. I would go for this option.
Watashiwateshdes
HannuKaa
Thanks for your tips. The adapter looks like handy and stylish. Minus side is the price over 100 euros here in Europe. There was also a comment about the battery life, but in my case this would not be in hard use.....or this is the plan sofar.
Do you have a comment about
http://www.amazon.co.uk/Flashgun-Speedlight-Hotshoe-Adapter-Cameras/dp/B002NDX6KS/ref=pd_cp_ce_1
which Amazon UK offers? The users' comments are positive.
I do have lot of expectatios for(?) NEX-7 comparing to my present 5D Mark II, which is too heavy and big e.g. in suitcase.
