Reply
by Visitor 1 Post
on July 2011
4 Replies - 9367 Views
Accepted Solution
PMB wont Download
I am trying to update PMB with the current version however everytime my PC finishes the download it tells me the connection to the download server failed.
I am not sure why this is happening but I had something similar with itunes, though I resolved this by editing the exclusions in Kaspersky. I have tried doing the same with PMB in Kaspersky but still no luck.
Any ideas?????
Thank you
The error msg is attached if it would help any one to help me!!!
Reply
New 9 Posts
PMB wont Download
Try downloading using PMB if you are downloading from the Sony Support Website. Run PMB, click on Help and click Check For Updates.
Reply
Expert 14,018 Posts
PMB wont Download
Hi masilve10,
welcome to Questions & Answers..:smileyhappy:
Have you tried temporarily pausing Kaspersky protection and  then try downloading..:smileyconfused:
Reply
Visitor 1 Post
PMB wont Download
Using Vista I have the same problem and I'm not using Kaspersky.
Reply
Visitor 1 Post
PMB wont Download
I had the same problem today using Windows 7.
Resolved by disconnecting Handycam from PC & pausing Kaspersky A/V.
HTH.
Geoff.
Newcastle upon Tyne
Reply
