Sony A330
dazieg14
Sony A330
Hello all
 having some issues with my A330 will no longer power on. I’ve changed the batteries and even bought new ones and a new charger. I’ve swapped the SD card over and nothing. There is a small red led on the front by the hand grip that flashes for a while then disappears.
Any ideas?
jumpsuit
Hi @dazieg14 and welcome to the Community :slight_smile:
If you've tried different batteries, chargers and powering off, removing and leaving etc.
then its probably best to get in touch with Support:
Support contact details
