Sony a77ii SD card question
mcgregorbart1
Hi all
could anyone advise the maximum size and speed of SD card that the a77ii will work with please. TYIA
CHEERS
Win_88
Specialist
Hi mcgregorbart1
The Online Help Guide lists some details on the supported memory cards:
https://helpguide.sony.net/ilc/1410/v1/en/contents/TP0000390699.html
Cheers,
Win_88
Sean_Mc
Moderator
Hi there,
I'm looking into this and will update the thread when I have more information for you.
Best wishes,
Sean
Win_88
Specialist
Hi mcgregorbart1
Cheers,
Win_88
mcgregorbart1
Thank you
