Sony A9 v2.00 Firmware Download Link
ianpollen
In light of the v3.00 firmware being withdrawn to fix a bug, does anyone have a link for the current v2.00 firmware?
I need to update an A9 body from v1.10
Sony, it would have been a good idea to put the v2.00 link back in place when you withdrew v3.00!!!!!
Ian.
Almou_10
Specialist
Hi ianpollen ,
I'm not sure if the previous update can be released again, however, I've checked the v3.00 and it seems to be okay for download now.
Cheers,
Almou_10
Hi there,
Thank you for the feedback. I will pass this on, and somebody should get back to you on this.
Best wishes,
M
Almou_10
Specialist
Hi ianpollen ,
Cheers,
Almou_10
ianpollen
V3.01 all installed, thanks for the heads up.
