sony ax200 DSLR-A200K
Paulinemck
I cannot get image on LCD screen pre photo taking
this means I have to look through small view finder to take picture
I have looked in my manual and cannot find anything that helps
Mick2011
Hi Paulinemck, welcome to the Sony Forums :slight_smile:
Like the a100 and a700, your a200 doesn't have LiveView, so you need to frame your shots as you would with a traditional DSLR, through the viewfinder.
The feature was introduced in 2008 with the a350 and spread to the rest of the alpha range after that.
Mick
Paulinemck
Hello Mick
thank you for your reply, I was sure I could see it before
must be an age thing!!
thank you
Kind regards
Pauline
