Sony DSC-W510 stamp date
profile.country.ro_RO.title
condurat.catalin1
My Sony Digital Camera DSC-W510 can't stamp date. After snap photo, appear on display but when I plug out the memory card and transfer to my lap top, the date is not stamp on the photo. Pls
Mick2011
Hi condurat.catalir, welcome to the Sony Forums
LIke many modern digital cameras, the W510 does not have a date-stamp function. What you see on the built-in screen is only for review and display purposes.
However, assuming you're using Sony PMB to download your photos, you should be able to add a date stamp once the image is on your PC. See the following tutorial for details:
http://support.d-imaging.sony.co.jp/www/disoft/int/pmb/feature/edit/attach_date.html
PMB for the W510 can be downloaded here: http://www.sony.co.uk/support/en/product/DSC-W510/downloads/PMB
Hope that helps :slight_smile:
Mick
Supergeoff
Hi , can you perhaps give me a model camara more or less the same type that supports timestamp on photos ?
IamNic
Hello @Mick2011,
this is not correct - the camera does support that the date gets saved directly on the image file as described here:
https://www.sony.co.uk/electronics/support/articles/00014743
Maybe this helps you as well @condurat.catalin1 and @Supergeoff.
- Nic
