Sony LA-EA4 Mount Adapter with APSC lenses?
danilow
I am about to buy an A7rIII but will have to wait a while before I buy any FE lenses to use with it. I have a number of a-mount lenses from my a77 but these are apsc rather than full frame. Does anybody know if I will be able to use apsc lenses on my a7riii using the Sony LA-EA4 Mount Adapter?
Sean_Mc
Moderator
Hi danilow,
I will try to find out for you. In the meantime perhaps someone else in the community may know if this is possible.
Best wishes,
Sean Mc
Win_88
Specialist
Hi danilow,
You can find a list of the compatible A mount lenses with the LA-EA4 adaptor in this link: http://support.d-imaging.sony.co.jp/www/cscs/accessories/compatibility.php?area=gb&lang=en&mdl=LA-EA.... Each lens will have a description to let you know what to watch out for and if there are restrictions to keep in mind.
Win_88
danilow
Hi Win_88
That's exactly what I needed, thank you very much!
Get Outlook for Android
