Sony memory sticks
ladylarch
Sony memory sticks
What length of movie do you get on 16GB and 32GB Memory sticks used in Alpha A77 camera
Hi ladylarch.
Let's see if my maths is up to this - if not, I'm sure someone will tell us!  It will depend on the recording mode.
At the highest AVCHD setting of 50p the recording rate is 28 Mbps which equates to 3.5 MB/s, so it will take 287 seconds to use 1GB = 4.8 minutes per GB.
At a MP4 (1440 X 1080) the recording rate is 12 Mbps which equates to 1.5 MB/s, so it will take 667 seconds to use 1 GB = 11 minutes per GB.
So at the highest settings a 16GB MS would record about 76.8 minutes and a 32 GB MS twice that = 153.6 minutes.
At the MP4 recording rates this would be 176 minutes and  352 minutes respectively.
With the A77 you have a choice of recording rates - 3Mbps, 12Mbps, 17Mbps, 24Mbps & 28Mbps.
I hope that gives you a rough idea????  I'm sure it is in the manual somewhere but it won't download at the moment.
:thinking:
Hi ladylarch.
:thinking:
