T-Mount adaptor for Sony A7S II
ilgainis
Hello happy ppl,
am trying to find T-Minus or T-Mount adaptor for Sony A7S II but no luck so far. T-mount adaptor is used to connect camera to the telescope.
Since a7s ii is full frame camera T-Minus  (2" ultra wide - Full Frame) would be ideal and T-Mount (1'25" APS-C) better than nothing.
Sadly I can not find T-Minus or T-Mount in UK marked and wondering if anyone knows where can we find this adaptor?
P.S. on 9th May 2016 Mercury will be passing in front of the Sun, so delivery from China will not make it on time and/or may damage Sony camera anyway :wink:
Another adaptor option could be
link: https://www.amazon.co.uk/dp/B0054EORJM/ref=wl_it_dp_o_pC_S_ttl?_encoding=UTF8&colid=3F1SHOS65QIA2&co...
But am confused reading a Note in item description below: NOTE: This adapter will NOT fit on the Sony a7S, a7 II, a7S II, and a7R II.
but why does it fit on other E-Mount cameras as a7, a7r, NEX-3, NEX-5 and etc.???
Thalamus.
Champion
I have tried to help in your other thread..
