Taking an NEX-5 to USA
awh18awh
Hi
I bought a Sony NEX-5 not so long ago and am planning to take it to the USA. My question is, will my battery charger work ok with a travel adaptor or do I need another lead/charger?
If anyone has recently been and could let me know that would be great!!
Andy
Your charger can accept an input voltage between 110 volts and 240 volts - so it will work fine with just a plug adapter.
However, if weight and bulk are a consideration, you may wish to consider buying a new lead with a US plug which will plug into your existing charger and take up a little less room.
http://www.amazon.co.uk/Figure-mains-power-cable-BLACK/dp/B000WOP02M/ref=sr_1_20?ie=UTF8&qid=1308264...
:slight_smile:
:slight_smile:
