ford lter size
pam193
ford lter size
hi all can anyone tell me the size of the filter for the Sony handycam FDR-AX33 4K , I think it is 52mm
PJ
pam193
hi all first time, can anyone help with the size filer for the Sony handycam FDR-AX33 4K I think it is 52mm
PJ
IamNic
Hello @pam193,
if a camcorder has a thread on the inner side of the lens, you can simply take a look at the front of the lens - it will have the value written on it.
For the FDR AX33 it though looks like there is no such thread.
- Nic
Mick_D
Moderator
Hi @pam193
You are correct – the filter size is 52mm.
Mick
