hdr-cx105e stream from pc
profile.country.el_GR.title
luckuman
hello i have the hdr-cx105e and i want to know if there is a possibility to connect it to my pc and works like my pc camera cause i buy an hdmi cable but my pc doesn't recognise the handycam. i want to stream from that camera.
profile.country.de_DE.title
cmosse
the HDR-CX105 does not support any kind of USB streaming.
If you want to use the camera like a PC cam you can use an analogue video grabber (e.g. a special video capture card or an external grabber, which is usually connected to the USB port) and connect the analogue audio/video output of the handycam to it.
See attached screenshot from the manual.
