I need driver for dcr-hc23e for windows 7, HELP PLEASE!!!
profile.country.sr_YU.title
Cuxios
USB streaming is not supported for Windows 7 but you should be able to transfer data to your PC using an iLink cable and the generic Windows 7 Drivers.
You need to download and install the updated Picture Motion Browser (Version 5.6.01) which is compatible because the Picture Package supplied with the camera will not work with Windows 7.
Go to the support page for your model and click on Windows 7 Compatibility to find the download: -
http://support.sony-europe.com/dime/camcorders/sd/dv/dv.aspx?site=odw_en_GB&m=DCR-HC23E
:wink:
