PMB database won't recognise media after HDD change
profile.country.en_GR.title
morph8070
Hi!
I have PMB 5.8.
I had my files and selected forlders for PMB on a USB 3.0 drive with drive letter "X". This drive crashed and I replaced it. I transfered all the files and structures exactly as they were in the original drive from a backup drive that I have. The new drive has, again, driveletter "X".
THE PROBLEM IS:
that PMB displayes thumbnails of the media but in "properties" it says: (unknown drive)\videos\name...
Is there a way to fix the database withought the need to re-check the folders? It only needs to see that the drive connected is "X" and the folder structure is exactly the same.
I'm using wondows 7 64bit, PMB 5.8
Thanks in advance
Tags (3)
0 REPLIES 0
