Sony Camera - HDR-TG3E - Problem with merging videos using cameras menu.
profile.country.el_GR.title
68149339
Dear all.
For the past few months I cannot merge HD videos nor by manual selection or date (written with my camera HDR-TG3E) using camera menu.
This feature was working prefectly in the past. I reset the camera with no results.
Does anybody has faced the same problem? Any advise?
Thanks in Advance for your assistance.
Theodore
10 REPLIES 10
blaireau_photo
Hello Theodore - Welcome to the Sony Forums :slight_smile:
Are you seeing some sort of error message when the camera doesn't allow you to merge these files?
Thanks,
Simon
68149339
Dear Simon
Many thanks for your message.
Please note that no error mesage appears. As soon as I press the OK the camera displays - executing - then OK but no video files are merged.
The same happens even if I choose to merge files by date.
Looking fwd for your reply thanking you in advance.
Theodore
blaireau_photo
Hello again Theodore :slight_smile:
As the screen displays the 'executing' message, have you checked to see if the merged videos are visible when the camera is plugged into a computer? It is possible that although they are not appearing within the camera, they may still be physically 'there' ready for viewing when connected to a computer.
Thanks,
Simon
68149339
Dear Simon
Thank's again for your reply/advise.
I will check to see if same appear in PC and I will let you know.:smileythumbsup:
Theodore
68149339
Dear Simon
I just checked to see if the merged videos are at least appear in my PC but no use. The videos appear as taken. The interesting thing is that my camera can divide the videos but it does not merge them despite showing so (executing etc).
Any other ideas?:smileyconfused:
Thanks in advance.
Theodore
blaireau_photo
Hello again :slight_smile:
If you have definitely already tried to reset the camera to the factory settings, you could try removing all video data from the memory stick and backing it up to a computer. Then, I would suggest completely formatting the memory stick and starting again - it may be an issue with data that is already on there.
On the camera, the option to perform an overall format is located by tapping 'HOME' --> 'MANAGE MEDIA' --> 'MEDIA FORMAT'.
Thanks,
Simon
profile.country.de_DE.title
cmosse
Have you tried out the "Repair image database file" option in the "Manage Media" menu?
68149339
Dear Simon
Thanks for the suggestion.
I have aleady tried that before (formating) in all three (3) memory sticks I have without any success.
Theodore
68149339
Dear Mr. cmosse
Thanks for your advise.:smileyhappy:
I have tried that before and many times without any success.
Any other ideas?
Theodore
