Sony FDR-AX 100E
profile.country.RO.title
Liv007-78.
Sony FDR-AX 100E
Hi,I have an FDR-AX100,somebody knows how could I work with it to make a large video because the camera is recording all the time but it save me the video like small pieces from all that it recordered.Each little clip has 12minutes and 36seconds.How could I do’it to record a large video,to not be necessary to edit in another program.I’m not working with it,I’m using it for familly!Thank you!
IamNic
Hello @Liv007-78.,
either you are using a FAT32 formatted card or a card which doesn't support exFAT.
You can verify that by checking if the clips have a size of 4GB (or slightly below).
I recommend to either use a SDXC card (since they support exFAT as file format) OR use PlayMemories Home to import the videos to your computer - PlayMemories Home will add all the small clips together to one continous video file upon importing.
- Nic
