sony handycam dcr-trv265e PLEASE HELP!!!
ralphsworksltd
PLEASE CAN SOMEONE HELP!
i have a sony handycam dcr-trv265e, i havent got the picture disc that came with it as it has been lost for a while, i have the il;ink cable and a windows 7 pc with windows movie maker on the pc but for some reason the cam corder will not connect to the pc, it says its installing the unkown device but then when i try to find it using windows movie maker it cant???
Would be SO grateful for any help
Many Thanks
Jack
blaireau_photo
Hello Jack - Welcome to the Sony Forums :slight_smile:
The good news about an iLink connection is that you will not usually need the original disc that came with the camera - you just need a fully functioning iLink/FireWire socket on your computer and Windows Movie Maker will do the rest. If the device is not recognised when it is plugged in to the FireWire socket, have you checked in the Control Panel to see if the iLink socket is installed correctly with the applicable drivers? It will usually be listed in the Device Manager as an input device, and you can 'right-click' on it and check the properties for any driver issues.
Thanks,
Simon
