Sony HDR-XR260VE Quality
mars006
I've bought a Sony HDR-XR260VE 10 days ago.
And the quality of the recorded movies is really bad.
It looks like its recorded with a phone or something.
And it seems like the ISO is really high, cause I have all the pixels visable in the footage.
And I filmed some birds, but it looks so cheap when I record it, even on the display of the camera itself. And on the TV or PC it looks even worse.
I also have a blue border around some white objects or birds...
I put the settings on highest quality and on 50P...
But still nothing happens.
Am I doing something wrong? I've tried all settings I think.
Thx in advance
PS: If somebody wants to see some footage let me know.
Tags (1)
4 REPLIES 4
profile.country.it_IT.title
sambro65
Ho comprato lo stesso prodotto anche io subito dopo Natale. Devo dire che non sto avendo gli stessi problemi (ne ho altri a livello di riproduzione dei files con alcuni players, non connessi con la qualità dei flies generati). Probabilmente il tuo esemplare è difettoso
I bought the same product too soon after Christmas. I must say that I am having the same problems (I have others at play files with some players, not related to the quality of the generated flies). Maybe your copy is defective
Message was edited by: -Soup-
blaireau_photo
Hello mars006 / sambro65 - Welcome to the Sony Forums :slight_smile:
First of all, have you tried performing a full reset of the camera to see if this puts the picture quality back to an acceptable level? For the HDR-XR260VE, there is a small pin hole that you need to press for a few seconds in order to reset the camera to the factory settings. In the picture below, it is marked as No. 7:
If this does not work and the video quality is still the same, it may help if you can capture a short clip that demonstrates the issues that you are describing. You can attach the clip to this forum message and I can take a look at it.
Thanks,
Simon
mars006
Hey,
Thanks for the response,
but the problem was that I used a Mediaplayer on the pc, that couldn't play the video's in good quality.
So the problem is fixed!
thanks alot
Mick2011
Thanks for the update :cool:
Useful to know that some media players can cause playback problems; glad you found a solution!
Can you remember the name of the player that didn't work, and let us know the one you're using now?
Mick
