Battery Charger - use in USA
Ollies-Guardian
Can I use the battery charger for my DSC-T90 in the USA using just a travel adapter?  Or do I need a transformer too?
Tags (2)
Hi Ollies-Guardian and welcome.
You will be OK just using a plug adapter as the charger operates between 100 and 240 volts.
Here is Page 162 of your manual: -
:wink:
5 REPLIES 5
:wink:
Thalamus.
Champion
Hi  Ollies-Guardian,
welcome to Questions & Answers..:smileyhappy:
Yes you should be fine, I have charged my cameras, mobile phones, using a plug adaptor in several different countries without any problems..
Ollies-Guardian
Thank you very much.
Thalamus.
Champion
You're welcome  Ollies-Guardian..:smileyhappy:
Ollies-Guardian
Thank you very much. I can go on holiday re-assured.
