Can filters and lens hood be fitted to HX100V?
TheBearGuy
There are some 3rd party solutions but I'd rather stay Sony. Any ideas?
Message was edited by: TheBearGuy
Tags (3)
blaireau_photo
Hi there - and welcome to the forums!
There is a lot of debate around regarding the HX100V and filters / lens hoods and it seems that a lot of users are spending between £10-£20 on an adapter ring and then purchasing from the huge range of existing filters and threads. Every adapter will work with different thread sizes but I think although it's always nice to keep everything 'Sony', if there is no other option available its always worth experimenting with a good quality adapter and these can be found easily on Google - check out some of the reviews as well.
Thanks,
Simon
blaireau_photo
Thanks,
Simon
TheBearGuy
Hi Simon
Many thanks for this. Seems like I'm on the right track. Just three follow-up questions: When you say an 'adapter' what exactly am I looking to Google please? Also, are you aware of any manufacturers I should be watching out for? Lastly, do you know if such things are intended to be left in place permanently and if so, whether they allow the lens to fully retract?
Andy
profile.country.ro_RO.title
ar14rai
http://www.hx100vadapter.com/
aici puteti gasi ceva ce puteti folosi la aparatul vostru Sony. Si ideea este foarte buna in a adapta parasolarii, filtre... Succes!
Si daca tot am revenit, cititi si aici:
http://forums.dpreview.com/forums/post/38651128
Message was edited by: ar14rai
