HX 20
lychnis
HX 20
For the HX 20, how can I download the user guide please. Not the Instruction Manual.
Message was edited by: -Cass-
Tags (1)
Thalamus.
Champion
Hi lychnis,
welcome to Questions & Answers..
Other than the instruction manual as far as I am aware the only manual that is available is the iManual that is viewable in your pc's browser - DSC-HX20/HX20V/HX30/HX30V User Guide - http://pdf.crse.com/manuals/4424086131/EN/index.html
9 REPLIES 9
Thalamus.
Champion
Hi lychnis,
lychnis
Hi Thalamus
Thanks for that.  Was hoping for a downloadable version so can print off.
nutmeg
Mick2011
If you have Adobe Acrobat Pro (or know someone who has) you can make a PDF from the web-based manual quite easily.
Alternatively, it is possible to print selected pages from the i-manual in most browsers.
Mick
lychnis
Thanks for advice, will give it a go.
Lychnis (nutmeg)
Thalamus.
Champion
lychnis wrote:
Hi Thalamus
nutmeg
Hi lychnis,
sorry wasn't aware you wanted a pdf version, here is a link to download a pdf version - DSC-HX20/HX20V/HX30/HX30V User Guide
However you may want to think twice about printing as it's 274 pages long..:smileyshocked:
As has been mentioned above I think it may be easier just to print of the parts that are of use to you..:smileywink:
profile.country.de_DE.title
cmosse
I have converted the i-manual to a PDF version. You can downlad it from here:
https://www.dropbox.com/s/arwp6b6gdyf05nm/DSC-HX20V_HX30_HX30V%20_%20Cyber-shot%20manual_En.pdf
lychnis
Hi Thalamus
Thats great, thanks.
atb
Lychnis
lychnis
Hi cmosse
Thanks for your reply
atb
Lychnis
Thalamus.
Champion
lychnis wrote:
Hi Thalamus
atb
Lychnis
You're welcome Lychnis..:smileyhappy:
