Sony Cyber-Shot DSC-WX350
andrecl
I'm buying a Sony Cyber-Shot DSC-WX350 for the summer. It seems to be a good choice for a good camera (better than my phone), but cheap enough to not care if it gets stolen.
I'm travelling for 2 months, so I have to buy a memory card big enough. I can see that it suports a number of card types. Which would be best to buy?
In order to get the best out of the camera, but not buy something unnecessary.
Pumpkin_Duke
I would recommend a SDXC memory card. They're not too expensive and you get them all over around the world.
PD
Pumpkin_Duke
PD
profile.country.IE.title
cuhullainn1
Congratulation!!
I had a Sony compact of higher spec ( inc GPS, Wifi, manual mode etc...) which was stolen and it really p... me off!!!
I bought recently the DSC WX350 for the same reasons you made. Takes a while to "trust" the camera but great value and great results!
I did order a screen hood to fit (sun glare)
This one is going with my on my next cruise instead of my (heavy) DSRL camera.
Enjoy!
