Timelapse on an RX0
dennisolsgaard
Timelapse on an RX0
Hi everybody
I need some help regarding the Sony RX0. I need to setup a timelapse that will be recording for around two years, one frame an hour 24/7/365. Is this at all possible on the RX0?
And will I be able to download the footage contiously via the wifi without touching the camera?
Hope anyone can help
Sincerely
Dennis, Copenhagen
IamNic
Hi @dennisolsgaard,
to my knowledge it is not possible to do this with the RX0, at least not without additional equipment (e.g. the network control accessory).
Since you would shoot 17520 images in total, I would say the FDR X3000 would be the better option to go with.
If you connect it to external power via a USB wall plug, set the timelapse interval to 60 minutes and the total amount of images to 'unlimited', it could shoot these images in 4K resolution (3840x2160 pixels).
- Nic
dennisolsgaard
Hi @IamNic
Thanks so much. I will check out the camera further, but at first glance it looks like what I´m looking for 🙂
