Apple IBooks
Elaine1942John
Apple IBooks
Can I copy Apple IBooks (epub files) to my Sony PRS-650?
Tags (1)
p4ult212
Hi Elaine,
So long as the eBook is an "EPUB" format, then it will drag and drop onto the Reader just fine. :slight_smile:
PDF files are also a simple drag and drop.
If you need talking through the process, let me know.
Hope that helps!
Paul.
