collection folder
mcrayven
collection folder
Hi
I have ebook reader prs-350 and i can not manage my collection folders. After i created the creation folders, the books just do not go there.
Second problem is with  Reader Library. Using this program I managed to send my files to collection folder, but it is impossible to create collection folder in this prgram. So if i have 1000 ebooks i have to transfer them to the Reader Library and then manually pick up those which go to collection folder. If i have to pick up 10 or 20 from 1000 it makes no sense. Why i can not create collection folder in Reader Library?
My third problem with Sony prs-350 is that i can not change the files' view. The files are big and ackward, making it difficult to find proper book, not mention of title which you see just half.
If I am wrong on any of these points please correct me :slight_smile:
specialist-convergence
Hi, I am sorry to advise there is no way to import existing folder/collections, you will have to import all books and create your collections within the Reader Library software.
In order to create a collection click on the library icon and then click the + symbol at the bottom of the Window, this will create your first collection icon and you can give it a name, now you need to drag the book you would like to appear in this colection from the Library view over to the Named collection folder, the books will still appear in the Library they are not moved, the library will always show all books on your PC.
Once you have made your collections attach your Reader, once the software shows the reader click on the expand > icon to view its folders, click on Sync and select your collections, if the books are already on the Reader I would advise removing them all first. Once you are happy with the selected ticked Collections hit Sync Now, your reader will list all the books from the collections under books or you can see each set of a collection under the Collections tab.
The only options to view on the reader are by title/author and so on, no icon or text changes are available.
I hope this helps
