question
minewma53
question
the screen on my prs300 e reader has frozen can anyone help me to un freeze it thanks
Thalamus.
Champion
Hi minewma53,
try doing a soft reset of your reader..
Reset the Reader by pressing a small pin or clip into the Reset hole on the bottom of your Reader.
Whilst pressing the reset pin slide the Power switch to on to start the Reader.
Thalamus.
Champion
Hi minewma53,
