Disappearing tv recordings made on my Sony KD43 Smart TV
RGBodies
Started to use the pvr ( personal video recorder) on my new sony tv and it worked fine for a couple of weeks but now the recordings are disappearing from my drive. One day they are there then they are gone. You can select a program to record and the TV records it, you can check immeadiatley after the recording and it is in the recording list and will play if selected. But if you go to play the recording next day its has gone. Very frustrating !! I have done a cold restart and a factory reset and its still the same.
rooobb
Are you sure the broadcaster has not set a validity limit on the recording?
