Help cannot register my ps4
V3RN3TTI
Hey there,
sorry if i publish here but there is no spoecific thread or forum for this issue.
I'm trying to register  my ps4 @ https://www.sony.co.uk/mysony/product/register
but it won't recognise my product cuh-2016a or allow me to enter the full serial number.
jumpsuit
Hi there :slight_smile:
Does your serial number have a 03 in it at the start?
I believe if you leave that out then the registration should work.
cheers
7 REPLIES 7
Peter_S.
Genius
You simply need to enter "PlayStation 4" which should allow you to register your product.
Peter
V3RN3TTI
yes I selected playstion 4 but when I try to enter the serial number I can't enter all the digits
jumpsuit
cheers
V3RN3TTI
Yes it does have the 03. I'll try, thanks
jumpsuit
No worries :slight_smile:
Good luck and keep us posted!
Hi - i have tried all the above but still cannot progress to register my PS4
BTW the Model#=>CUH-1116A
LCroft718
I am having the same issue. I type in my model number beginning with CUH and it disappears when I got to click register.
