Sony Ericsson W995 SpkrOn button . Where is it ?
mike749
Hi, Can anyone advise me where on my Sony Erricson the SpkrOn button is?
I want to listen to calls 'Hands Free'
The manual states to use this press and hold the SpkrOn, but does not illustrate where it is, it points to all the other function keys, but not this one!
Hi there,
Hopefully a community member can help.
Best wishes,
M
Dr_Chris
Hi Mike, don't know if you managed to solve this yet, but from what I remember when using the W995, during the call you should have an 'Options' menu on your screen which when selected and pressed using the multidirectional key and centre button, should give you the option to turn the speaker on, among other things. If this 'Options' menu isn't there, try pressing the call button during the call, or the Activity menu button  (small semi-circular button on the bottom left of the screen). Let me know if any of this works..
Regards,
Chris
