Sony M-48 CD player needs replacing which others are compatible with my HiFi system?
Pipron
5 REPLIES 5
Hi there,
Hopefully a community member can help.
Best wishes,
M
Joe_Dohn
Specialist
Could you tell us more about the setup you have and whether you're referring to the Sony CDP-M48 or a different model?
Pipron
It is the cdp m48 which is part of a hifi “tower” system with turntable, tape deck, tuner and amp.
Joe_Dohn
Specialist
I've managed to find the exact specs -which was not easy- here: https://www.radiomuseum.org/r/sony_compact_disc_player_cdp_m48.html
Unfortunately, since I don't own one myself, I can't say they are exactly accurate, but even within a ballpark they'll be useful in finding a replacement since you already know that this model is compatible, any other CD player with similar or higher specs should work.
Hope this helps.
J.D.
Pipron
Many thanks for the thoughts.
Sent from my iPad
