Sony Xav ax-100
Makumab
Sony Xav ax-100
Hello,
I'm having trouble connecting my iPhone to the radio. Every time you connect it writes the device is not supported, I tried several cables and phones but none worked always wrote the same. I tried connecting without a USB extension cable directly to the radio and no change. I have an iPhone 7 with the latest iOS and siri is active and the restrictions are on. I tried to restart both the phone and the radio and nothing has changed unfortunately.
Thank you for your advice.
Sean_Mc
Moderator
Hi there,
There is a possibility that the settings on your XAV-AX100 does not allow the device to connect to Apple CarPlay. Can you check the following settings below -
1. Tap Settings.
2. Tap General.
3. Set Restrictions > CarPlay > Disable Restrictions to on. The icon on the right turns green.
Let me know how you get on.
Best wishes,
Sean Mc
lukasssoo
Got the same problem.
Every time I connect Iphone got: USB device not supported. I checked with different cables and diffrenet Iphones (7, Xr and 11).
I have tried changing rules in Iphone as you said but it just dont work.
Android auto works just fine.
Win_88
Specialist
