When I switch TV on after about 1 minute screen reacts to usb
snafuu123
When I switch TV on - after about 1 minute screen reacts to usb which is permanently plugged in and I have to go to TV on the remote - this is a new occurrence  - how do I tell the tv to ignore the usb? (I know I can remove the USB but surely the tv can be trained to ignore it)
6 REPLIES 6
Peter_S.
Genius
A TV model would be helpful :slight_smile:
snafuu123
Humble apologies (This is all new to me)
TV details:  Bravie TV - Device name sony KD-43XD8305 Version 8.0.0
snafuu123
TV details: Bravia TV - Device name sony KD-43XD8305 Version 8.0.0
Many thanks
Dave W
Win_88
Specialist
Hi Snafuu123
Do you usually unplug the TV from the mains when not in use? I wonder if that has anything to do with it.
Also, make sure the software is up to date: https://www.sony.co.uk/electronics/support/lcd-tvs-android-xe85xx_x85xxe-series/kd-65xe8596/download...
snafuu123
Hi
I don't unplug the tv but I do switch it off
Many thanks
Win_88
Specialist
Well, try to unplug it for a minute every week or so as it helps refresh it.
Also, try that update and let us know how it goes
